Engine water and oil temps too cold >
Old 07-14-2013 | 11:40 AM
Default Engine water and oil temps too cold
I have a blown 454 and I am running a
Restricter instead of a thermostat. Also
Not running an oil cooler. Water temp 130
And oil temp is 175. Should I run an even
Smaller restricter to get temps up? I am
Worried about building too much water pressure
And getting my exhaust manifolds too hot.
tmbl52 is offline
Old 07-14-2013 | 08:10 PM
jbraun2828's Avatar
Those temps are fine
jbraun2828 is offline
Old 07-14-2013 | 10:51 PM
SFOcean's Avatar
Charter Member #394
As stated, those temps are fine; you definitely do not want higher water temp, 100 to 110 is what you want on a blown deal.
SFOcean is offline
Old 07-15-2013 | 12:54 AM
Lose the water restrictors and get a oil thermostat.
MILD THUNDER is offline
Old 07-15-2013 | 06:32 AM
It wouldn't kill you if the oil saw 200.
Ken
minxguy is offline
Old 07-15-2013 | 10:37 AM
I got 185 on the oil Sunday. I was under the impression
That I needed hotter oil to burn off any condensation
That may develop especially from running aluminum
Heads. I had a few drops of water when I changed oil
Last. Sounds like oil thermostat is the ticket
tmbl52 is offline
Old 07-15-2013 | 10:41 AM
Except I am not running a cooler for the oil so i guess that won't work
tmbl52 is offline
