Engine issues in my 98 Fountain...  Please help! >
Old 07-17-2013 | 06:46 PM
Sounds like fuel regulator to me!! You cant be running over 8-9 fuel psi on carb with some issues. At idle, that much psi over runs needle and seat and floods motor, but can sometimes handle it at higher rpms! You should not be able to see fuel dumping fuel in carb out of the boosters at idle.
Drinkin fountian is offline
Old 07-18-2013 | 08:27 AM
Yea I think the Fuel Pressure Regulator is the problem after taking it apart and seeing this: [ATTACH=CONFIG]504623[/ATTACH][ATTACH=CONFIG]504624[/ATTACH]
There was a bunch of crud in the needle area also. I it all clean now just waiting to get an oil change before I bring it back out for a lake test!
Attached Thumbnails Engine issues in my 98 Fountain...  Please help!-20130717_163259_resized.jpg   Engine issues in my 98 Fountain...  Please help!-20130717_163252_resized.jpg
Enforcer27 is offline
Old 07-18-2013 | 08:33 AM
looks like you have found the problem!
mike tkach is offline
Old 07-18-2013 | 08:39 AM
I agree with the other posts. To much fuel pressure. The reason t would run at high rpms is the motor was pulling fuel at a higher rate from the bowls. At idle it will push past the needle and seat and flood the motor. Basically the reason you saw black smoke and could smell fuel.
Is it just a fuel pump or a pump with a regulator?
cp5899 is offline
Old 07-18-2013 | 08:41 AM
Agreed... That's your problem.
cp5899 is offline
Old 07-18-2013 | 10:11 AM
Ah, the wonders of ethanol-laced fuel.
Budman II is offline
