Cleaning vinyl?
Gojo orange pumice hand cleaner will clean any stain or grime off of vinyl. Won't eat the material either... But be careful around the white thread. It'll tinge it orange if you get enough on there. Then treat with 303. I've had great results with it. Gotta do some rubbing but it works. No pun intended
Today I used Spray Nine ( not marine version) with magic erasure. Worked great! Then I put on Attwood vinyl cleaner and conditioner. The erasure left the vinyl dull. The Attwood left the vinyl shiny and slick to the touch.
I used the erasure on both with and blue vinyl. No issues at all.
Thanks again!
Thanks again!
Sea Tow had a bunch of StarBrite coupons so I bought a few products. My center console sits out on a lift, no tops allowed. It had mildew on the seat and around the console in the sealer almost since new. The Mildew remover did nothing. Spayed a bit more, the liquid turned a bit brown but not much happened. Not much happened... Not much happened, rubbing didn't seem to help. Moved on to a different spot then went back to where I started. All the mildew was gone! Magic It really worked. Tried it on the non slip too. Just wait for it and it works.
The Boat Guard spray and wax detailer sucks. It leaves a film that is hard to remove.
F
F
I'm not a pro but been using castrol super clean on all my white vinyl. It works great gets all the grim and oil crap off after I work on engine. After I use it I wash or wipe thorghly with clean water. I've used it with two boats over the last 15 years with no visibile of physical side effects. Just my opinion, need an interior guy to really answer this!
