-   -   Strering Problem (https://www.offshoreonly.com/forums/general-q/300560-strering-problem.html)
boatguy94 07-29-2013 07:04 PM
Strering Problem
My sister bought an 1993 Mach1 and it takes both hands to turn at any speeds. Thinking cable bad? ( fluid level good, belt tight)
phragle 07-29-2013 08:14 PM
pull the cable from the actuator and check..... Is it the same stiffness as when its not running??
MEANGREEN231 07-30-2013 12:14 PM
If its not the cable and the pump is functioning, its the actuator valve. The valve would be my guess unless that cable is really far gone.
