Very strange oil pressure issue...
Are you sure the distributor is turning the oil pump? Take the gear off and slip the dist into the block see if you can feel the pump by turning the rotor. If it works with the drill but not dist, maybe a short oil pump shaft????
I mounted a mechanical gauge on the transom, tee'd in the electric sender, any question I lift the hatch and trust the mechanical. With the sender on the transom, less vibration from the motor, supposed to last longer.
There is a major issue if you have zero oil pressure start with filter... If there's metal just stop and pull engine and tear down you will find the issue.....if filter checks go with the distributor thing... Start with what drives oil pump and move forward.....
Who built engine? Sure all clearances are correct? You spin a bearing you will have little to no pressure at idle... But can get some with rpm.... Like the other guy and I said... Cut oil filter tells a lot
