Early 525 & Smartcraft >
Old 08-07-2013 | 09:39 AM
fastlane40's Avatar
Default Early 525 & Smartcraft
Can someone explain how to connect Smartcraft to an early 525.
Its a 525 that uses a cam sensor in the distributor hole.
The engine harness has the round 10 pin plug and uses analogue gauges.
Where do you connect in the Smartcraft harness and will a VesselView work with this engine.
Will i be able to use analogue gauges and Smartcraft together.
Does the early 525 use an AGI for the analogue gauges to work and is it located near the PCM.
fastlane40 is offline
