Opinions wanted - best switchable mufflers
I am thinking I would like to upgrade to switchable mufflers! I am currently running the CMI sound elimination mufflers that are spring loaded and open and close automatically based on RPM/back pressure. They work awesome but I would like a little more control over when the exhaust is open (sometimes I like it loud at an idle! :) )
My pipes are 4.5" so what are the opinions, who makes the best switchable muffler? It needs to be clamp on and when closed needs to be legal! Lets hear it! Thanks Jim |
Well...pick your poison. There are air actuated and solenoid actuated. The air ones eventually leak and the electrics solenoids burn out. I had a nice pair of Eddie marine electrics and teague makes them also...they are almost identical.
Originally Posted by JRider
(Post 3973930)
Friend of mine has the Teagues and they work well and look nice. They are not clamp ons, however - install inside the transom. He has had to make some repairs to them over the years - replaced a solenoid and I think had to install a new pivot shaft when the original broke.
I have the Hardin air actuated version. Fourth season now with no issues (not even air leaks). These are the "switchable tips" version where the muffler can is mounted inside the transom and all you see on the outside is what looks like a standard tip. I'm not sure what type of dB noise suppression they offer, but it is noticeable when I hit the switch. I run Stelling Headers with wet tails so the sound is somewhat surpressed to begin with. There was a used set of Teague 4.5" being offered here on OSO not to long ago. I think the Teague version uses solenoids.
If it needs to be a clamp on the electrics I mentioned will not work. You would have to remove your tips, enlarge the holes. They look good when they are done though...look like 5" tips.
(Post 3975660)
http://i69.photobucket.com/albums/i4...b/078482c6.jpg |
| All times are GMT -5. The time now is 11:32 PM. |
