Biggest cam with CMI E tops >
Old 08-10-2013 | 05:02 PM
Default Biggest cam with CMI E tops
what's the biggest cam I can run with the factory 500efi CMI's without having reversion problems
Drock78 is offline
Old 08-10-2013 | 10:07 PM
Biggest isnt the best, there is a science behind cam selection. Best start by telling us about your entire set up, boat, engine build sheet etc.....
MEANGREEN231 is offline
Old 08-10-2013 | 10:13 PM
im looking at a going a different route with the engine since i lost a cylinder in mine. I want to still be able to run my headers and my switchable exhaust. looking going back to a carb motor but the motor im looking at is running a large solid lifter cam instead of hyd. and needs to run dry exhaust so I want to change the cam out so i can run my exhaust
Drock78 is offline
Old 08-11-2013 | 10:42 AM
Rookie's Avatar
If your still considering the engine I'm thinking about. Valako has a nice Hydraulic Roller Comp grind that would work good with that engine and heads. Lift and duration.
Rookie is offline
Old 08-11-2013 | 12:17 PM
Yes I am Jason. I'll call Jim this week and talk to him. I just want to be able to use my E-tops and switchable exhaust and not have any reversion
Drock78 is offline
Old 08-11-2013 | 08:51 PM
Rookie's Avatar
Jim runs a real mild cam on his 780HP 565. 230/236.
He can spec a cam. With those heads the lift is important.
I think the same cam he uses would be great in that engine.
I would run those solid Isky's on his hyd roller like I do. Lash them to 0.006"-0.007" and hold on.
They were sent out to Isky and rebuilt .
He can also order the cam for you.
It was a beautiful weekend out in GH so get at it! It won't last
Rookie is offline
Old 08-12-2013 | 01:11 AM
Cam choice will depend on many other factors. It depends on the cubic inches of the engine and head flow.
A cam that causes reversion in a 454 won't necessarily revert water in a 502.
Griff is offline
Old 08-12-2013 | 03:28 AM
betsybhqt is offline
