Safe boost with meth 50/50 mix >
Old 08-12-2013 | 09:43 PM
GPM
Originally Posted by skydog
Man I have thought about it, but not enuff...lol going to check on it more tomorrow!Thank u :-)
I think it's closer to 105 but it works great. We've been running it for two seasons now, no problems at all. You will need about 40% more at top end.
GPM is offline
Old 08-12-2013 | 10:38 PM
Originally Posted by Black Baja
I would definitely retard the timing. I'm not a whipple guy but I know with that kind of cam and a procharger you could put 16lbs into it safely with no water meth. The water meth stuff is usually used to cool down the intake charge rather than add octane. Mainly when not running an intercooler. If your running that motor on the ragged edge you better hope you have a good meth kit cause if the solenoid doesn't come on you can kiss your motor good bye. I know in the past the water meth kits were not very reliable and guys spent big money figuring it out...
Last year i have run with snow performance water meth kit, i run b&m 250 on 468ci at 10 of boost without intercooler great result until i had pump issue after about 20l of water meth, next time i will install a failsafe unit, this year i run at 6.5-7 of boost non intercooled.
supermx96 is offline
Old 08-13-2013 | 01:34 AM
Whipple Charged's Avatar
Its 600 with 8.200:1 compression, supper chiller, Dart pro heads, 260 intake at 50 and 268 exhaust at 50. 714 lift intake and 731 exahust 114 deg. It has a new Whipple 8.3 blower on her running 10PSI of boost at 800feet. Runing 91 fuel timming is locked at 32. Plugs are l Ngk 8s. What do you think is safe running meth 50/50. Was thinking 13-14psi would be 100% safe. Afrs around 11.5 Two 12 gph nozzles of meth.
Thank u
You really should be running 9 or 10 heat range plugs. 9 should be a minimum at your level.
Whipple Charged is offline
Old 08-13-2013 | 03:44 AM
Check E85, it strongly cool intake air.
High octane rating and much better
detonation protection than regular gas.
I use it my car with 60%gas / 40% E85
and wont need bigger intercooler or catles
downpipes and still can use 17psi boost levels.
shootitup is offline
Old 08-13-2013 | 06:10 AM
Retarding the timing doesn't always increase exhaust temps. If you have a good enough flowing port exhaust temp should not be affected. It's always better to turn back the timing and make a run. Slowly add timing and pay attention to performance. As soon as it looses a little it is pre detonating. If you run moly rings and it detonates one time it will eat the moly right off the rings...
Black Baja is offline
Old 08-14-2013 | 12:58 PM
I run meth and 34*
2BAD4U is offline
Old 08-14-2013 | 01:21 PM
Nice! Well new tune in, ngks 9s blower from 10% to 20% bigger meth nozzles,timming 32deg :-) time to go pro and let her eat!!!!!
Skydog
skydog is offline
Old 08-14-2013 | 05:57 PM
Video please!
Eliminated572 is offline
Old 08-14-2013 | 08:01 PM
Originally Posted by Eliminated572
Video please!
Yup if all goes right for sure!! :-) :-)
skydog is offline
Old 08-19-2013 | 02:35 AM
GPM
Well ?
GPM is offline
