Fed up with MSD and Accel, what other options? >
Old 08-26-2013 | 12:34 PM
Buying my crane hi-6 box today!
KRAUSMOTORSPORTS is offline
Old 08-26-2013 | 10:07 PM
Originally Posted by MILD THUNDER
I have no concerns. From a durability standpoint, they are potted in epoxy, just like MSD's ''marine" boxes. From a legal standpoint, I don't see USCG approved spark plugs, spark plug wires, coils, etc. I cant see a insurance company denying a claim because you didn't have a "marine" ignition box.
The Daytona Sensor's are USCG approved
Flamingo 42 is offline
Old 08-27-2013 | 03:12 PM
I ditched the MSD Marine boxes and replaced them with these. So did a buddy of mine. We were tired of the MSD's failing. We each have 2 seasons on the cranes, and no issues yet.
http://www.summitracing.com/parts/CRN-6000-6440/
Your not still running the Merc Distributor are you? If so how did you wire everything. I just called crane to verify and they stated it couldn't be done unless you run a different distributor alltogether?
Old 08-27-2013 | 06:29 PM
Rookie's Avatar
I am running the Merc distributor with my HI-6M but you do have to phase your rotor differently. Also I believe the only way to run the HI-6 is with locked timing, which is how I run mine.
Page 6 show the rotor phasing.
http://www.sportcompactonly.com/manu.../90006462b.pdf
Rookie is online now
Old 11-04-2016 | 09:33 AM
F-2 Speedy's Avatar
digging up an old thread............Im needing two for my new builds and am torn on what to buy, the crane are 200 bucks cheaper ?? but do less.......Im not going to need to GEEK out with all the extra's, I want something that works with no tinkering .............yes MSD is out
F-2 Speedy is offline
Old 11-04-2016 | 01:16 PM
I've been kicking the same thing around with new builds. I love my HEI dui flame throwers but an impossible fit with blowers. id rather poke needles in my eyes than chase ignition problems. Looking for very simple effective ignitions.
getrdunn is offline
Old 11-04-2016 | 01:31 PM
Can't you get the DUI distributor with the external coil? That should save a bunch of room. Not sure if it's enough, but the distributors are only like $215 without the coil. It is for EFI, but I don't know why it would be a problem to to an external coil VERY easy.
Just a thought.
BBCLiberator is offline
Old 11-20-2016 | 09:45 AM
F-2 Speedy's Avatar
Came across this, anyone running one ?? no ignition box required
http://www.ebay.com/itm/CHEVY-327-35...JYHfHT&vxp=mtr
Old 11-20-2016 | 07:12 PM
This kit is cool. This what I wanna do.
Expensive but badass. BBC or SBC
Adds a reluctor wheel to crank with custom timing cover and crank trigger.
Then just get a e38 LS ECM and coil packs. No dizzy. Super reliable.
https://www.eficonnection.com/home/c...ne/efi-58x-bbc
250ekelly is offline
Old 11-22-2016 | 06:20 AM
after few years, I still stand on the HEI's can't beat them for realiability, although did have the 1st bad out of the box a while back, now thats out of 8-10 I've used or sold, as far as blower clearance, not going to work, but If you are ok running locked timing think a small cap HEI EST with seperate coil might be worth a look. If you need a advance one there is a marine EST kit available with a built in curve(this is a crusader inboard set up that has about 20 deg of advance built in), I am not sure if DUI does a small cap unit or not but he may..and yes MSD(may soon die) is still junk in my opinion
ezstriper is offline
