Whipple Quad rotor carb set up >
Old 08-13-2013 | 01:05 AM
Randy Nielsen's Avatar
Default Whipple Quad rotor carb set up
[ATTACH=CONFIG]506138[/ATTACH][ATTACH=CONFIG]506139[/ATTACH][ATTACH=CONFIG]506140[/ATTACH][ATTACH=CONFIG]506141[/ATTACH]I bought a Whipple Quad rotor set up from a member on here a while ago. It came off of a Ron Sporl 598 tall deck making 1200hp. I would like to use it on something just for the wow factor. It is designed to use 2 dominator carbs however I don't have any dominators laying around, would it cause damage to the supercharger if I put a couple of adapter plates on it to use some 4150 series carbs? assuming 800-850cfm? Any Ideas? Randy[ATTACH=CONFIG]506137[/ATTACH][ATTACH=CONFIG]506136[/ATTACH][ATTACH=CONFIG]506135[/ATTACH][ATTACH=CONFIG]506134[/ATTACH]I also have a 10/71 Littlefi[ATTACH=CONFIG]506142[/ATTACH][ATTACH=CONFIG]506143[/ATTACH]eld blower set up for a small block with a alcohol injection hat. Any Ideas will be entertained no matter if it's boat or car. Randy
Attached Thumbnails Whipple Quad rotor carb set up-quadrotor-supercharger-001.jpg   Whipple Quad rotor carb set up-quadrotor-supercharger-002.jpg   Whipple Quad rotor carb set up-quadrotor-supercharger-003.jpg
Whipple Quad rotor carb set up-quadrotor-supercharger-004.jpg   Whipple Quad rotor carb set up-superchargers-001.jpg   Whipple Quad rotor carb set up-superchargers-002.jpg
Whipple Quad rotor carb set up-superchargers-003.jpg   Whipple Quad rotor carb set up-superchargers-006.jpg   Whipple Quad rotor carb set up-superchargers-004.jpg
Randy Nielsen is offline
