502mpi oil Consumption
I'm at 740 ish hours on mine and they use the same as when I got the boat with 230 hours. I hear they have low tension piston rings so that's why they use oil. Also the higher rpm you run them the more oil you will use. A quart every 10-20 hours depending on use is what I see with merc 25w-40
