Oil Leaks...Help !!!!! >
Old 08-04-2002 | 07:48 AM
Default Oil Leaks...Help !!!!!
Trying to locate oil leak somewhere in new motor.
I have tried the obvious.. pan, harmonic balancer, remote oil filter.
Can somebody give me a few hints where else to look???
This is driving me crazy...
Sheikman
sheikman is offline
Old 08-04-2002 | 08:43 AM
Audiofn's Avatar
Charter Member #232
were is it in the bilge? Front back?? Did you run your hands over the engine to try and find it that way? What engines are they?
Jon
Put your best foot forward!
Audiofn is offline
Old 08-04-2002 | 09:07 AM
Default Oil leak
Engine is a chev 540
I have been looking all over.
I think it leaks around 3000rpm and up
Checked around the filter boss and remote set up. Trying to get to the drain plug..
THanks
Sheikman
sheikman is offline
Old 08-04-2002 | 07:19 PM
mopower's Avatar
Toxic FORMULA
Hey Sheikman ,
Try the dipstick tube...I know two people who had that problem...and yes, it was over 3000 rpm. Excess blow by caused pressure in the crankcase and forced oil up the dipstick tube
This also showed up with dampness on the same side of the engine as the tube.
mopower is offline
Old 08-04-2002 | 07:51 PM
MACDAD260's Avatar
Charter Member #818
Is the dipstick tube sealed up with silicone where it goes into the pan? Do you have a remote oil drain hose? If so it might be the cause if it is leaking. Do you see or smell oil burning. Maybe a valve cover leak. Hard to see them with the exhaust on. Rear main seal? Oil filter adapter? Oil line fittings? Lots of possibilities. Good luck.
MACDAD260 is offline
Old 08-04-2002 | 07:54 PM
blue thunder's Avatar
I had bad oil leaks on both motors. Turned out to be I had cast aluminum pans that didn't have two holes in the back that the block had. Normally with the stamped pan bolts filled the block to fasten the pan. Not with the aluminum pan. Had to pull each motor to plug the bolt holes. I'm suprised more people with this pan don't speak up about this problem.
BT
blue thunder is offline
Old 08-04-2002 | 08:06 PM
formula31's Avatar
I had the same problem as BT. Couldnt believe I didnt see it when I was putting the pans on. Learn something new all the time. Mine behaved just like a bad rear main seal and blew the oil out around the starter hole in the flywheel cover.
formula31 is offline
Old 08-04-2002 | 08:24 PM
Yea Formula31, but the dumb ass I am, I replaced the rear main and pan gaskets oon the port eng and still didn't figure this out. It wasn't until Marc at bam suggested I pressurize the crankcase with air it became obvious! Then I still had the other motor to do.
Oh well, all is good now... even the drive which you helped me with.... I (and the wife) still thank you for your help my friend!
BT
Old 08-05-2002 | 11:15 AM
JON242
Blue Thunder -
What's the procedure for pressurizing the crankcase. I'd like to try that to find a leak that's driving me crazy.
Old 08-05-2002 | 09:23 PM
Sheikman,
Take a mag light and a mirror and look over the entire block the connection for the remote oil filter often does not leak until the motor is warm.
If you fail here they do make a special die to put into the oil that does respond to a black light this may help you.
I have not used one but have heard it is nice to have especially when you are looking for a leak on a black motor with gloss paint.
Post your findings.
Good Luck
Big Boys Toys is offline
