Carb tuning
#51
#52
#55
#57
Anybody have knowledge of blow thru's? Don't mean to hijack your thread Dan but considering the turns this thing took already didn't think you'd mind.
I'm trying to figure out a stumble that almost always happens when the power valve opens. This happens at all loads, RPM's and any power valve used. I was going to change out the power value restrictors but my $1300 Carb shop carb came with less than the desired bleed type screws. Time to get the drill. Also, I can only get 1/2 of a turn on the idle mixture screws before it goes way rich at idle.
I was thinking or starting with the idle feed restrictors since opening the idle bleed really didn't change much. After this, and getting at least a 3/4 turn on idle mixtures screws go after the power valve restrictors. Any thoughts?
Yes, I know this is a car. but the Carb Shop guy is useless. "Didn't do it on the dyno"
#58
