-   -   Outdrive Noise (https://www.offshoreonly.com/forums/general-q/30247-outdrive-noise.html)
24outlaw 08-05-2002 01:53 PM
Outdrive Noise
OUTDRIVE STARTING TO MAKE NOISE IN CERTAIN TRIM POSITIONS.WHAT COULD IT BE.WHEN TRIMMED ALOT IT WANTS TO PULL TO ONE SIDE???
DOCTOR DAVE 08-05-2002 02:24 PM
what kind of noise? could it possibly be a u joint?
Allan4 08-05-2002 03:21 PM
Scraping/rubbing/grinding sound, probably gimbal bearing (24 OUtlaws need alot of trim, eats up gimbal:D)
Knocking/clanking when turning could be coupler or u-joints.
Check outdrive fluid and also see if you have a heavy white chalk on the top outer casing of the drive. THat would mean a hot outdrive which would probably mean low oil, butI doubt that alone would make any clunking noise. That'a about as far as I know, for the internals you have to ask someone else. HOwever, typically if you have an outdrive problem it will grenade pretty quick.
Also, if it is pulling alot and feels "loose" you BETTER CHECK THE STEERING CABLE!!!!!!! If it is worn and you do not have some sort of hydraulic steering or assist, you are going to be in some serious **** if that cable breaks.
24outlaw 08-05-2002 03:59 PM
YOU CAN HEAR AND FEEL THE DRIVE TURNING .IT ECCOS TROUGH THE COCKPIT,ITS BEEN GRADUALY GETTING LOUDER. ONLY MAKES NOISE IN DRIVE OR REVERSE
Tinkerer 08-05-2002 10:32 PM
CHECK THE DRIVE OIL LEVEL
fastfred252 06-12-2005 08:07 AM
Re: Outdrive Noise
i have the same problem but the gimbal goods and the u-joints are fine. What else could be the problem.the drive oil is also full.could it the lowere unit cause i already went to a shop and checked the upper,what could be the problem
