stainless marine sbc maifold clearance
does anyone know if sbc stainless marine manifolds will clear tall valve covers without a spacer?ordered some today and forgot to ask.the covers are gmpp cast tall covers.thx in advance.
Someone might give you a straight up answer but I looked at mine and it looks like you could go maybe 3/4 to 1 inch taller than stock center bolt covers. How much taller than stock are they?
They will NOT clear the normal squared edge ones. I used them on a vortec stroker motor I built for my previous boat. You can also get a steel spacer for the manifolds and use tall fabricated ones that have slight angle to the edges. Spectra performance sells a decent set of fabbed vented bolt ones that I used.
2 Attachment(s)
Originally Posted by grant6395
(Post 3997595)
1 Attachment(s)
[ATTACH=CONFIG]508175[/ATTACH]
There was full roller rockers under these. Wasn't worth it. |
Originally Posted by formula 382 sr-1
(Post 3997684)
No they will not clear but you can use these with a thicker gasket.Our 383's in the old 272 Formula it's what we used.
As said above, they will NOT fit, I tried thicker gaskets didnt work, ordered a set of 1" spacer thought that might work it only made the problem worse. FYI if you need a set of spacers I have a brand new set & two brand new sets of super nice tall square aluminum 3/8 flange valve covers haha......
I used retro style Edelbrock finned tall cast covers. I had to heat and gently clearance the covers with a curved body dolly. They clear the risers and Comp pro-magnum rockers, and I can remove the covers without issues.
| All times are GMT -5. The time now is 11:14 AM. |
