Thermostat or not? >
Thermostat or not?
Thermostat or not?
Old 09-18-2013 | 10:41 AM
bck's Avatar
bck
Charter Member#568
Default Thermostat or not?
When you're putting an engine in a boat for the first time how do you determine if you should be using a thermostat or not? Seems like you need to know this up front so you can buy the correct parts to run one if needed. This would be for a NA 540 making 650 hp in lake erie. Thanks
Straight bottoms and flat decks
bck is offline
Old 09-18-2013 | 02:50 PM
Ran-Dom 32's Avatar
I was researching this recently, lots of opinions.. I found the general consensus was to use one on a N/A motor, I have similar power as you 557 N/A motors & I run 140's - the gauges read 150 while cruising, Blower App is another story - you want them to run as cold as possible
Ran-Dom 32 is offline
Old 09-18-2013 | 08:59 PM
bck's Avatar
bck
Charter Member#568
Assuming you know what temp you want to run how would you know if you would require a Thermostat to hit the temp prior to running the engine in the boat? If you're buying a crossover and housing how do you know if you should get one that has the bypass? Can you just guess that if its a na motor that it should run a thermostat?
bck is offline
Old 09-21-2013 | 05:25 AM
I dont run a thermo, blocks run about 110 after warm-up/ but I run thermo oil coolers, set at 180. The shop that build motors said to keep the water pressure lower at high rpms to not use the thermos. The setup works great. 540cu merlin tall decks, huber trans, arneson drives.
Inrecovery is offline
