Strange fuel tank issue >
Old 09-22-2013 | 07:33 PM
Default Strange fuel tank issue
I have a sonic 35ss, 725's super charged, bravos. The boat has 2 70 gal aluminum tanks which were replaced in 1997. I have only owned the boat for 2 years and bought it as a complete project.
The port side tank uses much more fuel than the starboard . Each engine runs independent on its own tank. There is no fuel valves or crossover that I can see. In fact it is a very simple fuel system . 1/2" line with AN fittings straight from tank to mech fuel pump then to fuel filter and then to carb. Port tank drains 1/3 faster than other.
Here is a list of the tests I have done so far:
Filled both tanks to the top, ran the boat then topped both tanks again, results 45 gal used port . 30 gal used startboard.
I did that test several times with always the save results.
Next I swapped the fuel lines so the port engine now draws from the starboard tank. The problem does not follow the engine it stays with the port tank. Again I filled both tanks to the top, ran the boat for a while and topped the tanks both off again . Port tank took 1/3 more fuel .
There is NO smell of gas at any time and my bilge has no signs of fuel.
Any ideas??????
billy boats is offline
Old 09-22-2013 | 09:57 PM
Do your fuel vents have a loop in them? I have seen them siphon over the side. Loop is important.
dirty dan is offline
Old 09-22-2013 | 10:16 PM
Are the engines fuel injected?
If so, are the return lines going to one tank
If carbs, do the fuel pumps have a return lines going to one tank?
Cajun 2 Stepp is offline
Old 09-22-2013 | 10:19 PM
Not fuel injected as I said simple fuel system one single line per tank
I would think it I was loosing fuel through the vent that I would smell it. The fuel fills and vents are right next to the helm
Old 09-23-2013 | 03:07 PM
MnFastBoat's Avatar
Charter Member#157
Nice comparison. My cat is somewhat the same.
I have always burned more gas Port side. I have ran out of gas port side several times too
i have not done actual measurements like you, but I will always put more gas into the port tank!
I have lead it to be the fact that port drive, at least on my Cat, is turning out thus working a little harder?
I have been told by many that the port side turning out will work harder. As well my port side has always turned slower with the sticks equal,--rpm that is. I always have to give more stick for port to keep the rpms equal.
Not saying this is your answer, due to higher amounts of gas used, because I cannot prove that.
Just saying mine is set up the same, except injected 502's. One line to each motor, and both return lines to the corresponding tanks.
Edit, I have never swapped lines to opposing tanks but that is a very interesting thought and thinking I will keep that on the thought to do sometime.
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
