Need a Spark Advance Table Chart from 502 EFI
what year 502 and what is the stock cal id on the sticker on the edge of the computer.
mefi1 or mefi3-009 or 999
i will post for you the stock values
stock 502 mpi cool fuel mefi3-009
Main spark table based on RPM (3600-6000) and MAP (3600 MUST BE SAME AS PREVIOUS TABLE)
RPM* MAP
30 40 50 60 70 80 90 100
6000 40.1 40.1 38.0 36.9 35.9 35.2 32.0 29.9
5800 40.1 40.1 38.0 36.9 35.9 35.2 32.0 29.9
5600 40.1 40.1 38.0 36.9 35.9 35.2 32.0 29.9
5400 40.1 40.1 38.0 36.9 35.9 35.2 32.0 29.9
5200 40.1 40.1 38.0 36.9 35.9 35.2 32.0 29.9
5000 40.1 40.1 38.0 36.9 35.9 35.2 32.0 29.9
4800 40.1 40.1 38.0 36.9 35.9 34.8 28.1 26.0
4600 40.1 40.1 37.6 36.6 35.2 32.0 26.0 22.9
4400 40.1 40.1 37.3 36.2 34.1 28.1 23.9 21.1
4200 40.1 40.1 36.9 35.9 34.1 28.1 23.9 20.0
4000 40.1 40.1 36.6 35.5 34.1 27.8 23.9 20.0
3800 40.1 40.1 36.2 35.2 34.1 27.4 23.6 20.0
3600 40.1 40.1 36.2 35.2 34.1 27.1 22.9 20.0
Main spark table based on RPM (1200-3600) and MAP (1200 MUST BE SAME AS PREVIOUS TABLE)
RPM* MAP
3400 40.1 40.1 36.2 35.2 34.1 27.1 22.9 20.0
3200 40.1 40.1 36.2 35.2 34.1 27.1 23.9 20.0
3000 40.1 40.1 36.2 35.2 34.1 27.1 23.9 20.0
2800 40.1 40.1 36.2 35.2 34.1 30.9 25.0 20.0
2600 40.1 40.1 36.2 35.2 34.1 32.0 26.0 21.1
2400 40.1 40.1 36.2 35.2 34.1 32.0 26.0 22.1
2200 33.0 33.0 35.2 34.1 33.0 32.0 26.0 22.1
2000 25.0 25.0 33.0 32.0 32.0 30.9 26.0 21.1
1800 20.0 20.0 30.9 30.9 30.9 29.9 26.0 20.0
1600 16.9 16.9 23.9 29.9 29.9 28.8 26.0 20.0
1400 14.1 14.1 14.1 28.8 28.8 28.1 26.0 20.0
1200 12.0 12.0 12.0 22.1 28.1 27.1 26.0 23.9
Main spark table based on RPM (200-1200) and MAP
RPM* MAP
1100 12.0 12.0 12.0 16.2 25.0 25.0 25.0 23.9
1000 10.9 10.9 10.9 14.1 22.1 22.9 23.9 20.0
900 9.8 9.8 9.8 12.0 19.0 21.1 22.9 15.1
800 9.1 9.1 9.1 9.8 16.2 19.0 22.1 9.8
700 8.1 8.1 8.1 9.8 9.8 16.9 21.1 4.9
600 6.0 6.0 6.0 8.1 8.1 4.9 4.9 0.0
500 3.9 2.1 2.1 0.0 0.0 0.0 0.0 0.0
400 3.9 2.1 2.1 0.0 0.0 0.0 0.0 0.0
300 3.9 2.1 2.1 0.0 0.0 0.0 0.0 0.0
200 2.1 2.1 2.1 0.0 0.0 0.0 0.0 0.0
RPM* MAP
RPM* MAP
RPM* MAP
RPM* MAP
RPM* MAP
RPM* MAP
RPM* MAP
RPM* MAP
RPM* MAP
As I stated earlier this is typical timing for a stock MERC motor. They reduce overall timing as the rpm and MAP increases. The Scorpion motors and other small blocks are nearly identical, including the 40 degrees of advance on hard vacuum/snap idle conditions.
I think he's puzzled by seeing the advance reduce as the rpm increases above the mid 3000 range, yet that is normal. I've seen it on my motor too.
Im happy to find some people who understand me !!
Tunertech, this is what im looking for. This Tabel from a 502 Mefi3 is what i need in my 502 Mefi1.
I dont no, is somebody a company that reprogramms ?? Ore all only user with high technical understanding ?
My EMC Model are 16159919 Service 16165414 on the ECM.
Tunertech have you the same Tabels from a HP500Efi to compare ?
What total spark advance did a carb 502 run on WOt I've i check it with a light gun tool on WOT ?
Hello
have someone a spark advance Tabel from a 502 EFI ?
In the Mercruiser Service Manual 16 i can only see the advance from the voyager distributor module. But i can nowhere find something about a advance tabel from the ECM Modul ??
I drive today a 500EFI it makes total at over
2000 RPM total are in diacom 28*. Real 36* 28* + 8* = 36*
My 502 EFI
makes 2800 RPM 30* in diacom and real
than 3100 RPM 33* in diacom and real ( No Nock retards 33 + 8 = 41 this is not real and can not work)
than over 3200 RPM 28* in diacom and real
With real i mean showen with light gun timing tool.
Have someone a Tabel from this Engine ??
Ore now what advance this engines make ??
My 502 EFI
When you have the motor in base timing mode, 1500RPM, your timing light, if adjustable needs to be at 0. Then, you will line up your pointer to the 8deg mark on the balancer. If, you have an adjustable timing light set to 8deg, and mark your balancer/pointer at 8 deg, then you have 16deg base! This is a common mistake. If you have your adjustable timing light at 8deg, then you MUST line up your pointer and balancer at the 0deg mark.
The best timing lights are the very cheap, non-adjustable that run off a 9v battery. Then you just line up your pointer and balancer at 8deg. Then this is exactly what the ECM is looking for base and there is no way the timing light can be off.
I have one genV and one genVI. So i need a timing light that can adjustet.
I adjust the light to 8 and move the light an baloncer plate with the distributor to 0. all in base time mode.
Than i doppel check it with adjust the light to 0 and show on 8 on the baloncer plate. Thats fit. The other genV have only one point plate stick, i hope this is 0. i adjist the light to 8 and it points on the stick 0.
So if this is correct both on 8. both have the same Hex9334 software modifed ore hex9550 original. Both softwares make 29.53 total at WOT.
You mean this are 29,53+8=37,53
I have test 6 base time with better speed but most i have test more base time 9,10 and 11 but this are bad at midrange.
Have someone a unmodified tabel from a 1993 mefi1 ? For see the diffrence to my to versions ?
