Help what Company programs MEFI1 >
Old 10-03-2013 | 07:35 PM
MikeScarab28XLT's Avatar
Default Help what Company programs MEFI1
Hello I need help.
What company programs mefi1 ECM ?
My last program make keitheickert.
I have post him, but he don't have time for me.
I take to many time for the last support.
It was 2011 and now I like to program something diffrend.
What company can do this.
Change the spark advance table on my HEX9334 mefi1 ECM.
Thank for all help.
MikeScarab28XLT is offline
Old 10-03-2013 | 07:55 PM
i use mefiburn.com also called obd diagnostics .real good guy to deal with
smokin' gun is offline
Old 10-03-2013 | 09:35 PM
Precision Marine in Louisiana has a good reputation. Also mefituning.com ...don't know much about this guy, but he seemed pretty sharp when I talked to him.
liquidlounge is offline
Old 10-04-2013 | 01:33 PM
Scott from Keitheickert have time for me and help me again. Thank Scott for your Help !!
Old 10-04-2013 | 03:29 PM
Bob from MEFIBurn can help. If you are savvy you could get the software and work on the timing table yourself. MEFI 1 is one of the easier ECMs to play with simply because it lacks the complexity and fidelity of the later MEFI units.
Trash is offline
Old 10-04-2013 | 03:46 PM
www,mefituning.com
tunertech is offline
Old 10-05-2013 | 04:05 AM
What do you think about this ??
Is it normal ??
Where is the problem ?
This old ECM shows the real total advance in Rinda. The 29.53* at WOT are real with light gun tool.
The 33* befor 3200RPM are real too.
Old 10-05-2013 | 04:08 AM
This is a HP500 and Rinda shows the advance. 28 + 8 = 36
Old 10-05-2013 | 02:13 PM
Are your engines stock????? If yes, then just run a stock mercruiser ecm tune or one that is slightly modified.
Griff is offline
Old 10-05-2013 | 03:11 PM
20 years stock.
4x rebuild with new engine blocks and allways stock. Only thumber power exhausts.
I have stock ecm Hex 9550 and modifed ecm hex 9334 from keitheickert. Both did the same.
Is this normal ? Ore are something else wrong on my engines ?
