fixing to blow up a boat! >
Old 10-05-2013 | 04:11 PM
whiskeyhangover's Avatar
I haven't checked the fuel water separator yet i'll go do that now and see where it's at
whiskeyhangover is offline
Old 10-05-2013 | 04:22 PM
Yeah.... the fuel and water separator is completely full.... just checked it
Old 10-05-2013 | 05:57 PM
28Eliminator's Avatar
I agree with smokin' gun
try swapping the dist or the module. You could also rig up a meter to the wires on the VST pump, or just jumper it directly to the battery to test. Just need to start isolating and figuring out what isn't working. If you think the problem is with the ECM, try swapping that also. Hope you get it figured out!
28Eliminator is offline
Old 10-05-2013 | 06:04 PM
Hook a timing light up to any of the plug wires...1 is ok .....See if when the motor dies the light goes out ....that will tell you definatly whether it is fire or not ....You could also have a fuel pressure gauge attached on same test and watch results ...it's ez
Obviously check for water in fuel
motor is offline
Old 10-05-2013 | 07:40 PM
thank you to everyone! I think i have fixed the problem. the boat has 2 water/fuel separators on each motor....why? i have no idea.
I bypassed the Racor water/fuel separator and connected directly to the one on the motor and it ran fine. I just think that trying to run
a 4-7 psi fuel pump through 2 water/fuel separators might just be a little to much.
Old 10-05-2013 | 07:58 PM
I had my 5 yr old daughter turn key.
Did she fix the boat? Pretty cool to your kids by your side when working on the boat
blaquebaja is offline
Old 10-05-2013 | 08:22 PM
dought its the problem .been running like that till now and the other motor runs fine and its set up the same way
smokin' gun is offline
Old 10-05-2013 | 08:49 PM
She likes to play around in the cuddy usually while i am tinkering. My 8 yr old boy would rather stay inside playing, but not her.. dirt is her middle name. Usually, she just take my tools and plays with them then i am like wtf, where did it go!! Lol
nailit is offline
Old 10-05-2013 | 09:17 PM
Expensive Date's Avatar
Thinking they are like 6.2s. When you key on the pumps go on for 10-15 seconds then shut off if the do not detect oil pressue. There is a switch on the right side rear of a 6.2, its not the sending unit just tells the ECM there is oil pressure. That might be bad if your engines have it. A quick fuel pressure test will tell if they are in fact shutting off.
Expensive Date is offline
