convert to crossovers on twin 575sci >
Old 10-14-2013 | 09:01 PM
Default convert to crossovers on twin 575sci
anyone ever done it, new thermostat housings are $1295.00 each, is it worth the change over,
senza is offline
Old 10-15-2013 | 09:46 AM
I am running a Stainless Marine crossover with a bypass on my built 524 (700hp) and it works great. I make sure the Merc seawater pump is healthy and the engine temps stay within range even when running really hard. I think the big trick is to use a Stewart racing thermostat with the 3 relief holes. I boat in everything from 40 degree water to 75 degree water and the temps are very consistent. After running hard and dropping to an idle my temps will go from 160 to just over 185 and then come right down.
ThisIsLivin is offline
Old 10-16-2013 | 08:07 AM
bcfountain's Avatar
Registered User
why was the cost of your cross-over so high?i only paid about 350.00 for cross-over and t-stat housing.?jus wondering
bcfountain is offline
Old 10-16-2013 | 11:52 AM
I believe that the $1295 is for Merc Tstat housings and he is wanting to switch to less expensive crossovers.
Griff is offline
Old 10-16-2013 | 03:52 PM
that is correct $1295 each, what a rip off by Merc . my 575's run such a perfect water and oil temp I really hate to mess with it, but, $2,600 for 2 little thermo housing it may be time to make the change
senza is offline
Old 10-28-2013 | 10:21 PM
ttt
senza is offline
