572sc questions >
572sc questions
572sc questions
Old 10-18-2013 | 05:02 PM
Question 572sc questions
Hello out there,
Questions for some knowledgeable & experienced engine people. Helping a friend with a rebuild project. He has some 572's.
Thinking this combo should produce about 1050hp-1075hp @ 5800-6000 rpm with 93 octane. (is this realistic ??)
Looking for reliability and lower maintenance hence using a hyd roller.
Specs: 572ci
Dart 355cnc heads w/ 2.30 intake valve
8.2 compression
BDS 1071 @ 10psi w/ intercooler
Nickerson 850 carbs
MSD ignition
Camshaft is a hyd roller ---
@ .050 243/251
lift .627/.632
LSA - 113
2" primary exhaust pipes
Here are the questions:
Does the cam need more duration? or what would you recommend
are the 850 carbs large enough?
do the primaries need to come up to 2 1/8" or 2 1/4"?
safe ignition timing?
Thanks in advance & much appreciated
Jim
PS-- long time lurker ( raced NHRA pro stock years ago, I'm familiar with motors, but not current w/ a marine BBC)
jjtoma is offline
Old 10-19-2013 | 07:05 AM
Sounds like a nice build. The cams are a bit short on duration for a 572 in my opinion. I'd also rather see some 1050CFM 4150 style carbs on it. 850's are a little light for a 572 and 10lbs of boost. I'd probably start with timing at 30-32* with the 4.5" stroke.
I'd probably be looking at cams with around 252/262 @ .050
Im not a pro, so you may wanna talk to Eddie Young, Haxby, Bob madera, etc.
MILD THUNDER is offline
Old 10-19-2013 | 09:19 AM
i have a pair of 588s with the dart 355 cnc heads,cams are 258/270 at .050.i have 8.3L whipple,s making 13 lbs and im at 34 timing,dist is locked.i am useing quick fuel 1050 cfm 4150 carbs.imo,your setup should make 1000 hp with a proper tuneup.
mike tkach is offline
Old 10-19-2013 | 12:38 PM
cams need more lift..
FIXX is offline
Old 10-21-2013 | 04:19 PM
Holy ****e. 1400hp?
hogie roll is offline
Old 10-21-2013 | 05:40 PM
Originally Posted by korvetkeith
Holy ****e. 1400hp?
I wanna say they made 1218hp with 12psi? Heads are box stock. No porting, hyd roller setup.
Old 10-22-2013 | 06:12 PM
This boat will be run on the Great Lakes. Any of you guys running thermostats? What water temps do you like ?
Thanks again
jjtoma is offline
Old 10-22-2013 | 06:17 PM
Keep em cool, no stats. Just get oil stats, to keep oil at operating temp.
