-   -   ARP main bolts vs studs 4 bolt mains (https://www.offshoreonly.com/forums/general-q/304401-arp-main-bolts-vs-studs-4-bolt-mains.html)
Borgie 10-19-2013 05:14 PM
What seems to be the general rule of thumb regarding marine BBC 4 bolt mains regarding bolts vs Studs? Asking as I'm building around a 600hp motor with forged parts and have been told arp bolts are more than adequate.
MILD THUNDER 10-19-2013 05:18 PM
The bolts will be fine. Unless of course, you upgrade to some Rect port heads :gfight:
Borgie 10-19-2013 05:22 PM
BAHAHAHA touché sir!
MILD THUNDER 10-19-2013 05:33 PM
Don't forget to check the line hone
Borgie 10-19-2013 05:36 PM
Yes I definitely will be double checking everything. Think I'm just in the overbuild mindset with head studs and mains when they are really not needed whatsoever in this kind of application.
Borgie 10-19-2013 05:55 PM
Do you know if the ARP 135-5201 fit a gen V with factory windage tray?
MILD THUNDER 10-19-2013 07:01 PM
no go with the stock windage tray. You'll need these from GM.
http://www.summitracing.com/parts/NAL-10224104/
I'd have no worries using the GM fasteners with a 4 bolt main block at 600HP, especially in a low rpm marine engine. If you told me you were building a 7000RPM deal, that's different. Overall, im not a fan of the Gen V blocks, but that's irrelevant.
Borgie 10-19-2013 07:24 PM
Thanks! Yeah I've considered looking for a gen VI 454 block and have heard they match better to a gen 4 style head like my DARTS. But can't seem to find many and the ones I do stumble on people want big $$$ for them.
f_inscreenname 10-20-2013 09:42 PM
What's wrong with the Gen V? All are 4 bolt blocks (unlike the mark IV that are 2 and 4 and the 4 bolts are getting harder and harder to find), better oil system then the mark IV, 1 piece crank seal. I think the reason they got a bad wrap was because of the no fuel pump boss and non-adjustable rockers but they are easy fixes for anyone building a motor.
When you just compare then Gen V to the Mark IV (and not what they should have done ie, roller rockers and fuel pump boss like the gen VI and leave out the Gen V it was behind its time) its as good if not a better motor then the Mark IV. I'll take one any day.
bcfountain 10-22-2013 02:12 PM
the only time I use studs is when I cannot find a 4bolt main block.bolts should be fine
