Digital Ignition Control Box!!! >
Old 10-24-2013 | 05:59 PM
Originally Posted by 1stoutlaw
OK----changed over the ignition system today from the Max Volt to MSD--------SAME F-------THING--backfires out the exhaust---spins like a top-give her a squirt of gas--Booom out the exhaust-----Sooooo It can't be the box???? This is the 3rd brand new box I have put on her???
ok lets go back to the basics..what dist you using? what your describing is that your dist is out 180* or if using the merc dist its not compatible with nothing but the Daytona sensors or crane box..
FIXX is offline
Old 10-24-2013 | 06:15 PM
Yep. Sounds to me like the distributor was installed 180 off, or extremely retarded.
MILD THUNDER is offline
Old 10-25-2013 | 06:30 AM
MER Performance's Avatar
[ATTACH=CONFIG]510870[/ATTACH]
This a diagram, showing phase correction of rotor.( This may not even apply to this problem)
As far back as I can remember, if you are 180 out. I do not even think the engine will run, just continue to pop through the intake and exhaust. If the rotor phasing is not correct in reference to using a crane or daytona box you will misfire.
MER Performance is offline
Old 10-25-2013 | 09:06 AM
I wonder if maybe the engine has a mechanical problem,did you do a compression check?
mike tkach is offline
Old 10-25-2013 | 09:52 AM
I am wondering the same thing.
Old 10-26-2013 | 11:17 AM
OK---as far as the dist off 180 deg--unless it broke at the bottom--the engine ran perfect for the 1st twelve hours---like a top--no misfire-no skips-real smooth...she ran perfect flushing out the motor at home-to-a day or 2 later , backfiring out the exhaust!!!!????? Knowing everything installed on the motor-and the whole motor is brand spanking new, I can't believe it is mechanical problem, rather than a fire/ignition problem....HOWEVER, i'm not that smart....The engine tech told me not to touch it, until he gets a chance sometime next week-end...Thanks so much for all the input, as I guess right now it could be any of the reasons you guys brought up !!!! Thanks-Mike
PS-the dist being used came as a whole ignition kit----box-wires-magnetic pick up-coil--again all brand new-nothing was used over from the last engine--Thanks!!!
1stoutlaw is offline
Old 11-16-2013 | 04:12 PM
OK--finally today , checked timing ---dist was retarded alot--pulled dist-found a broken snap ring inside attached to the magnetic pick-up------when turning it by hand the ring would sometimes move and lock the gear-----lower gear on the cam was fine--keyway was fine--there are no snap rings in a dist----so it was believed it was picked up at the factory , by accident, when they were building the dist ,--re-installed dist--re-timed same---AGAIN-Thank goodness--Runs like a top---Thanks for all the idea's and input......Mike-Tampa Bay !!!!
