Merc 454 TPI work on 496 with no issues? >
Old 10-31-2013 | 01:42 PM
I'll swing by my storage later and get some pics and post them up. Be picked up the intake from Summit.
Baja Rooster is offline
Old 10-31-2013 | 01:51 PM
I was wrong on the motor. This is the unit here, a bored and stroked 454.
http://bit.ly/YrBnff
This being the case I guess my question would be is the FI a bolt up and go deal, or do you send the ECU out to get flashed like I do with motorcycles?
Old 11-01-2013 | 03:13 AM
That re-man engine was built with Pro Comp components. All new for $3,999.99. You are going to have trouble.
RODS ARE BRAND NEW PRO-COMP
CRANKSHAFT IS BRAND NEW AIRCRAFT QUALITY PRO-COMP CAST STEEL
CYLINDER HEADS ARE NEW PRO-COMP ALUMINUM RECTANGLE PORT
ENGINE MAKES 576HP @5400RPM AND TORQUE IS 640LBS @4500 ALL DONE ON 91 OCTANE
Originally Posted by Baja Rooster
....I guess my question would be is the FI a bolt up and go deal?
Not a chance.
dbkski is offline
Old 11-01-2013 | 08:29 AM
Originally Posted by dbkski
that re-man engine was built with pro comp components. All new for $3,999.99. You are going to have trouble.
Rods are brand new pro-comp
crankshaft is brand new aircraft quality pro-comp cast steel
cylinder heads are new pro-comp aluminum rectangle port
engine makes 576hp @5400rpm and torque is 640lbs @4500 all done on 91 octane
not a chance.
plus 1 ........................and thats all im saying!!!!!!!!!!!!!!!!!
FIXX is offline
Old 11-01-2013 | 11:02 AM
Is it a fitment issue or bad parts?
Old 11-01-2013 | 01:13 PM
Originally Posted by baja rooster
is it a fitment issue or bad parts?
ok me personally have run across a bad set of cylinder heads castings were thin and leaked water into the cylinders..from what i see from people is that they are not machined properly to spec..typical china parts..
FIXX is offline
Old 11-01-2013 | 01:23 PM
Ah... Yea it looked like basically a cheap truck motor.
