Is there to much steam coming from my exhaust??? >
Old 11-01-2013 | 03:34 PM
Default Is there to much steam coming from my exhaust???
2 weeks ago I took her out and she ran fine. While I was flushing I noticed steam coming from my exhaust. This boat is new to me. The previous owner said he had changed the water pump impeller a few months ago, but had to flush the system due to a failed impeller. My engine temps are fine, and water pressure gauge is reading 20 while on the hose in the video. I flushed for 10 min and did not see any changes in the amount of steam. This is a 496 Mag HO with Whipple. I haven't had any problems so far (knock on wood ). Just wanted to get some opinions on whether this looked normal. Thanks!
https://www.youtube.com/watch?v=iABQ...e_gdata_player
Brad.M is offline
Old 11-01-2013 | 04:00 PM
the amount of steam seems normal but 20 lbs on the hose does not seem right.
mike tkach is offline
Old 11-01-2013 | 08:46 PM
Sounds like you have a misfire if you listen real close...also check the trailer brakes,,the one port rear wheel looks like its covered in rust like the brakes are grinding..
FIXX is offline
Old 11-01-2013 | 09:53 PM
I think what you hear is my exhaust flaps, they are pretty loud. I do have to check the trailer brakes because they prob haven't been changed since 2002! I am curious what the "norm" would be as far as pressure readings when on a hose though. My last boat would always be at 20 when I would flush it.
Brad.M is offline
Old 11-02-2013 | 01:41 AM
My water pressure at idle on a hose or in the lake is 1-3psi and it was the same on my previous boat. They are both raw water cooled though.
The steam does not look to be excessive and looks pretty normal.
Griff is offline
Old 11-03-2013 | 02:07 PM
I was going to say the same, sounds like there is a misfire.
BIGBREW is offline
Old 11-03-2013 | 02:29 PM
What should I do to address that.....change plugs?
Brad.M is offline
Old 11-03-2013 | 02:37 PM
Yea new plugs and wires on a new boat is always a good idea.
Captain YARRR is offline
