-   -   Odd failure of exhaust hose (https://www.offshoreonly.com/forums/general-q/305020-odd-failure-exhaust-hose.html)
CrownHawg 11-05-2013 10:58 AM
Last summer, when I changed my oil on my starboard engine, I noticed a slit in the starboard exhaust hose coming off the riser that goes out the back. I thought, no problem, I'll order a new one and replace. Well, that was about 4 months ago, and this past weekend when I winterized it, I noticed ANOTHER slit in that very hose I just replaced. This was a brand new hose. Is there something going on that could cause this hose to fail prematurely? It's not a big dollar piece, and not that hard to replace, but it's got me spooked that there is an underlying problem. There is nothing even near this hose that could cause the holes, like a belt or moving part. Both times it was on the top of the hose, about halfway from the riser.
Knot 4 Me 11-05-2013 11:06 AM
Pic? Is the hose routed nice and straight to where it hooks up to the exhaust tip or Captain's Call diverter?
CrownHawg 11-05-2013 11:09 AM
Straight shot! No CC. The hose is not in any kind of bind.
Sydwayz 11-05-2013 11:16 AM
Hatch coming down and contacting it?
30ftpanther 11-05-2013 11:40 AM
Is there a chance that you replaced the old hose with the old hose and not the new hose? Pictures would be helpful.
Ted G 11-05-2013 11:53 AM
What does the inside look like? If it looks overheated you may have a water flow problem.
CrownHawg 11-05-2013 12:48 PM
I would figure if I had a water flow problem, the water wouldn't be squirting up through the hole (how I found the leak in the first place). Sorry, no pics right now. The boat is tucked away at our lake place. The old hose looked fine except for the quarter inch slit, just like the new hose, it showed no signs of heat related failure (black or burnt). It sits below the level of the riser, so the hatch would contact the riser before the hose. I guess it's possible that I goofed and replaced the faulty hose with the faulty hose, but I'm sure that after I installed the "new" hose, it wasn't leaking anymore. I thought it might have been the baffle (plastic piece in hose) but the leak ocurred several inches from the baffle. I guess I'm going to order a couple extra hoses, in case more than that one gives away. These are on a twin 496HO Advantage. Although the hose is not that hard to replace, anything else on these engines (read impellor), is an absolute BEOTCH to get to. Took me 8 hrs last spring to replace those.... I really need a boat monkey...LOL!
Knot 4 Me 11-05-2013 12:50 PM
Try the blue silicone hose this time and see if you get the same result.
CrownHawg 11-05-2013 12:54 PM
I really can't see that there is that much pressure on those hoses, it's not like I'm running a fire breather like some here. There should be little or no back pressure. But, I'll try the blue silicone hoses. Thanks!
CrownHawg 05-30-2014 01:57 PM
I recently replaced my leaking exhaust hose (well, about a month ago), and found the oddest thing. After an inspection of the hose, it looks like it is being worn from the inside. The only thing I can figure, is there is a pin point spray of hot water coming out of the riser focusing on a small spot on the inside. Looks like it has been water blasted out. I will try to get a pic this weekend, but other than the small worn spot, the hose looks brand new! I have only seen the one riser so I can't be for sure if it is the only one, but the end that goes into the hose looked crumpled instead of a smooth round horn.
