Low Compression on 525? (new problem, new thread) >
Old 11-05-2013 | 05:59 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Probably broke when your wife used it for a hammer .
the deep is offline
Old 11-05-2013 | 07:24 PM
i had a similar problem with my old snap on tester,the schrader valve was bad,i replaced the schrader and all is well.
mike tkach is offline
Old 11-05-2013 | 08:07 PM
I could try that. There is one inside and another on the outside to release the pressure. I'll put a new one on the inside and try it before I buy a new one. That won't take long.
thirdchildhood is offline
Old 11-06-2013 | 10:55 AM
Yay! 135 psi, engine cold, throttle closed. Manual says 140 w/engine warm & throttle open. I'm good! So this morning I'm looking at my 30+ year old compression tester and I'm like, ah, no, not gonna try to fix it. Bought a new one.
Old 11-07-2013 | 08:11 AM
good deal...cheaper than engine repair !
ezstriper is offline
Old 11-07-2013 | 09:44 AM
Good news. You can now resume breathing. LOL
sonicss42 is offline
Old 11-07-2013 | 08:40 PM
im glad your problem turned out to not be a real problem,no go and buy a lottery ticket because you are lucky.
Old 11-08-2013 | 09:06 AM
Thanks guys. I was worried there for a little while. I lost a Bravo XR upper this year from a nut backing loose inside and the money tree has been plucked clean. Now to finish the winterizing and get ready for another Michigan winter.
Old 11-08-2013 | 04:15 PM
and carl,,when its time for a valve job look into a set of afr heads....
FIXX is offline
Old 11-08-2013 | 10:00 PM
Originally Posted by kvogt
do you have a 6 ft hose connected to the tester?
Does a 6 ft. hose give a lower reading?
Revd Up is offline
