Bravo transom seal dry or 4200? >
Old 11-30-2013 | 11:37 AM
  #61
Thanks for the link. The drive is a Bravo. I need to confirm X Dimension before I pull the trigger on this. It appeared to be quite deep from eyeballing it, although hard numbers are the only real way to establish what I have currently.
Borgie is offline
Old 11-30-2013 | 04:34 PM
  #62
blue thunder's Avatar
You can't really go wrong then as you can always use a spacer to lower the drive again if needed.
blue thunder is offline
