What would be the best ignition modules ??? Info on them???
I am looking for some info on the 500 and 525 ignition modules.
The two rear engines have the 525 (848823-2) ignition modules and then center has a 5F23A V8-HP ignition module. I am looking for any timing info and rev limiter info on these modules. I am looking at doing all three the same so what would be the best ignition module to run on a triple 42 running 500 HP’S with CMI exhaust? Thanks for any help |
Send me your email addy and I'll send you a TB IV and V manual. Has all you want to know wbaout TB ingnition, including curves and troubleshooting.
Thank you for the info waybomb.
I found these two modules info and figure I would post them. I will post more as I find them so to help others also. Maybe someone has some to add. MCM 502 MAGNUM/MIE 8.2 Identification Mark: V8-20R Module Advance: 20 Degrees Initial Timing: 8 Degrees BTD Total Advance: 28 Degrees MCM 7.4L/MCM 454 MAGNUM/MIE 7.4L Identification Mark: V8-24 Module Advance: 24 Degrees Initial Timing: 8 Degrees BTDC Total Advance: 32 Degrees |
2 Attachment(s)
What engines and ignition do you have??? Those are Thunderbolt IV modules that you posted specs on. Used only until about 1996-1997 on 500HP's and never on 525EFI's
The ignition modules you should most likely be running are the V8-HP's that came on early carbed 500HP's. You could also run the V6-14 modules which will give about 10* of advance on a V8. Here's all the specs on TB IV modules |
Griff,
Thanks for the info…. My engines: Trip 500 HP’S with CMI exhaust My modules: two rear engines have the 525 (848823-2) and center different style has a 5F23A V8-HP Modules: (848823-2) Have MHP 525 SC paper label, on the back metal side stamped in ink 11S ___20A. I do not see the 848823-2 on your list but as I looked at the back I am thinking that the 20A is the amount of advance. I am not sure what the 11S is??? This module is the square type with metal back. The center engine has the 5F23A V8-HP which is mounted on the metal triangle bracket, different style plug than the others. That is a nice chart with the advance curves. Would you have that info for the 848823-2? |
Your part numbers do not come back to anything when looking them up. I can't tell what you have, but I can tell what you are supposed to have.
You should be running V8-HP modules. That is what came stock on carbed 500HP's. You should also be setting the timing based on total advance of 32-34*. Stock HP500's get set at 12* base with 20* of advance. Base timing really does not matter that much. Just set it for the correct total advance. The 525SC stock module a V8-22A. It is the first V8-22 module on the curve table |
I have attached pictures of the modules.
http://i199.photobucket.com/albums/a...f/IMG_7073.jpg http://i199.photobucket.com/albums/a...f/IMG_7074.jpg \ |
525-SC V8 Thunderbolt IV 96-97 0K000012 & up 13524a1 na na 91019a3 848823t2 805443t
Race sterndrive 525SC gen Vl Thunderbolt V ignition module
should be 11 base and 20 advance |
The pics are of TB V ignition modules.
There were some HP500 TB V modules for sale in the swap shop a few weeks ago. |
Would the HP 500 be better to run than the MHP 525 SC module??
Thanks again for the help..... |
The HP500 modules have a better advance curve. I would run them.
Would anybody know the Ignition module advance curve of the (848823-2) MHP 525 SC? Or if it would be the same as any of the older styles listed below?
V8-20R, V8-HP, V8-22, V8-24, V8-24S. Thanks for the help |
| All times are GMT -5. The time now is 03:03 PM. |
