Gen 4 heads on a Gen5 >
Old 12-01-2013 | 11:04 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Default Gen 4 heads on a Gen5
Know this has been asked before but can't seem to find the thread. What head gaskets are needed to run Gen 4 heads on a Gen 5 block. Any one have a fel pro # And will the gen 4 push rods work??Because the Gen 5 heads used the non adjustable type rocker studs.Thanks JOHN SR
Fenderjack is offline
Old 12-01-2013 | 11:24 AM
Gen 5 head gaskets, I think 17048 for 454, 17049 for 502? May be way off have to check those numbers and pushrod length needs to be measured.
Unlimited jd is offline
Old 12-01-2013 | 09:29 PM
Default fixx
[QUOTE=Fenderjack;4034867]Know this has been asked before but can't seem to find the thread. What head gaskets are needed to run Gen 4 heads on a Gen 5 block. Any one have a fel pro # And will the gen 4 push rods work??Because the Gen 5 heads used the non adjustable type rocker studs.Thanks JOHN SR[/QUOT
its going to be his or mis,,some people have problems with water in oil leaks doing this and some dont,,i say stick with the gen 5/6 head and use the arp rocker studs for that gen 5/6 head..or go with the conversion kit ... http://www.competitionproducts.com/G...ductinfo/6172/
FIXX is offline
