water crossovers pros cons
ran my 500hp without a stat and bypass, never got over 100, switched to bypass and 140 stat, ran 150 after that...helps burn off condensation in the oil...you could run a thermostat on the oil cooler as well...
i run cross overs on mine and inorder to get the temperature i want i used a ss washer to act like a restrictor insted of a thermostat. Thus holding water in the block longer to gain temperature. After experimenting with sizes i got it right on the money.
