Fuel cooler. Anyone using them? >
Old 12-17-2013 | 05:11 PM
Default Fuel cooler. Anyone using them?
Anyone using a fuel cooler in a carb supercharged application?
MILD THUNDER is offline
Old 12-17-2013 | 05:47 PM
Yes ss930's outerlimits has coolers for the return fuel
Unlimited jd is offline
Old 12-17-2013 | 06:04 PM
i am going to add them in on mine.
mike tkach is offline
Old 12-17-2013 | 11:15 PM
I like my fuel like I like my Florida weather... HOT!!!!
ICDEDPPL is offline
Old 12-18-2013 | 06:14 AM
Will the cooler actually cool the fuel? Or will it heat it? The fuel bowls on my carb tend to get a little frosty after some hard running. I know of a boat that has triple 525/whipples and they actually used a heated fuel line on it cause the lines were freezing up.
Black Baja is offline
Old 12-18-2013 | 09:53 AM
it's my understanding that fuel coolers were introduced because of the "closed loop" fuel return system to the filter or regulator and not returning to tank, or having no return. By looping the fuel it would return warmed fuel and then loop it again, causing gradual increase temp on fuel. I would assume varying fuel temp can alter the dynamics on afr. returning fuel to tank, or always having a fresh supply such as a carb setup wouldn't need a fuel cooloing system. I am sure there is a brainiac on the forum that can tell us the optimum fuel temp. Too cold, I would assume impacts fuel atomization, too hot probably causes something as well. but then, i am guessing!
larry
ldillow is offline
Old 12-18-2013 | 05:15 PM
larry
Makes sense
Old 12-18-2013 | 05:57 PM
fuel lines freezing up in a boat,id have to see it to believe it,unless it is being run in northern alaska.
Old 12-18-2013 | 05:59 PM
larry
the op was asking about supercharger,carbed engines.
Old 12-18-2013 | 07:06 PM
Rookie's Avatar
Never had a fuel line freeze up, but after a 10+mile run @ 6000+RPM I have opened my hatch and my carbs were white with frost. (they are painted red)
Kind of shocked me.
Rookie is offline
