Stainless bolts thru aluminum >
Old 12-28-2013 | 10:14 AM
Question Stainless bolts thru aluminum
I bought stainless bolts for my bellhousing. Even thou the bolts go into the engine block I`m not sure if thats safe to do ?? Stainless and aluminum dont like each other correct?
ICDEDPPL is offline
Old 12-28-2013 | 10:23 AM
Not sure on compatibility, but aren't the stainless bolts softer/weaker then a regular bolt?
abones is offline
Old 12-28-2013 | 10:32 AM
Default hmmm
The bellhousing coolers have stainless screws without issue it seems...
ICDEDPPL is offline
Old 12-28-2013 | 10:44 AM
tcwcar's Avatar
Joe
ICDED my bravo bellhousing had SS bolts in it from merc, in fact every bolt in the motor (ext head bolts) are SS bolts, and if your using SSbolts and SSNuts together make sure you use antiseeze if you don't they could guild up....
tcwcar is offline
Old 12-28-2013 | 11:06 AM
I also use stainless on any exterior bolt on the motor. Intake and bellhousing are aluminum along with other stuff.
f_inscreenname is offline
Old 12-28-2013 | 11:14 AM
Why not use grade 8 bolts and grease the threads? The gold plating is either cad or zinc and will rust but they are a lot stronger than the stainless bolts.
Are stainless bolts strong enough for a bell housing application?
Keith Atlanta is offline
Old 12-28-2013 | 11:26 AM
ARP makes a grade 8 equivalent stainless bolt.
KWright is offline
Old 12-28-2013 | 11:31 AM
Stainless is plenty strong enough. The studs in the gimbal bell housing are stainless, the bell is aluminum.
Unlimited jd is offline
Old 12-28-2013 | 11:34 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
I think its more of an issue when submerged in water, like your aluminum drive that has SS studs and nuts. That's were you'll always see the corrosion start
US1 Fountain is offline
Old 12-28-2013 | 11:49 AM
tcwcar's Avatar
Joe
Try this, http://www.totallystainless.com/Catalog.html the company name is totally stainless, get all my stainless steel bolts, nuts, washers from them, they also list them by strength from grade 2/3 to stronger than grade 8, the grade 8 or stronger are ARP bolts and TS bolts and you can buy all items in any amount of the different items you want....
tcwcar is offline
