Hydraulic roller profiles? >
Old 01-06-2014 | 09:15 PM
Default Hydraulic roller profiles?
Just wondering if anyone knows what cam companies have large hydraulic roller profiles. Looking for 280 290 @.050 .700 lift range.
Black Baja is offline
Old 01-06-2014 | 09:33 PM
Biggest I know of is 262/270 .680 lift cranes .
MILD THUNDER is offline
Old 01-06-2014 | 09:46 PM
Crane has a few new ones 272 282 .714 just a little on the small side.
Old 01-06-2014 | 09:55 PM
That's a fair bit of duration. What's the application? Call Bob Madara, if you really need something that big, one of his custom 55mm cores should do the trick. 585-654-8583
HaxbySpeed is offline
Old 01-06-2014 | 09:58 PM
You building a 454 with Peanut Port GM truck heads and a dual plane intake??
Old 01-06-2014 | 10:07 PM
Those heads really wake up around 8000rpm..
Old 01-06-2014 | 10:09 PM
Originally Posted by haxbyspeed
those heads really wake up around 8000rpm..
lmao!!!
abones is offline
Old 01-06-2014 | 10:13 PM
280-290 @ .050 I gotta ask what are you putting that cam in
motor is offline
Old 01-06-2014 | 10:15 PM
it,s like magic!
mike tkach is offline
Old 01-06-2014 | 10:16 PM
Hahaha!! Especially if you weld up the port floors and keep the small valves
