Mirror sheets for engine hatch
What is being used to put on the engine hatch as mirror material? Polished SS sheeting, Acrylic Mirror Sheet, polished aluminum diamond plate? these are some of the ideas I had. Second question is what would be the best way to adhere it or fasten it to the engine hatch?
I used stainless on my donzi and it came out great (the second time). On the first go around I laid the hatch upside down, put down some epoxy and then the stainless. I added weight to secure it until dry. Low and behold the curve was gone out of the hatch. Had to remove and reinstall in a bowed position to make the hatch match the deck. Also note the stainless adds some weight.
I used 3m tape on both my cigarette boats for plexiglas mirror. I used a lot but it worked well. The surface was gel coat finished under the hatch for your info. Held 1/8" no problem. But I used quite a bit. Depends on your surface.... Good luck
