-   -   Help- lost signal- GPS speedo (https://www.offshoreonly.com/forums/general-q/30734-help-lost-signal-gps-speedo.html)
Cattitude 08-12-2002 02:22 PM
I installed a Nordskog digital speedo about 6 wks ago. Everything has been great, really pleased with the product.
This weekend I had no signal, all weekend. I have the optional "mouse" antenna, secured under the dash reading through the fiberglass- always worked fine since day one. For giggles I moved the antenna outside for a direct look at the blue sky- still no signal.
All my connections seem fine, properly secured, strain relief in mind etc, well tie wrapped.
Is there any way to test individual pieces- anything else I should be checking?:confused:
Wally 08-12-2002 02:34 PM
If you have a hand held GPS with a NEMA(i think that whats its called?) output you should be able to test the headunit to see if thats the culprit.
Does the Speedo go through a diagnostic check upon first activation like the Livorsi unit does? Maybe that right there can signal you somehting that may be causeing the problem?
Cattitude 08-12-2002 02:53 PM
I've got an ETREX which i supsect I can buy a cable for and try as you advise.
I've got my system wired hot all the time to preserve my big number- it does not do a diagnostic mode all the time that I know of but i will pull juice and reset just to make sure.
Ken
