K & N Flame Arrestor For HP 500 Carbed >
Old 01-15-2014 | 02:52 PM
Default K & N Flame Arrestor For HP 500 Carbed
Which would be better?
The 59-3370 9" dia. 5" tall element.
Or
The 59-3414 14" dia. 4" tall element.
GETTINBYE is offline
Old 01-15-2014 | 08:10 PM
There won't be any performance gains with either over each other or over a stock flame arrestor.
Griff is offline
Old 01-16-2014 | 10:10 AM
jvthundercat's Avatar
Either would be fine. I would go with the 9" to keep more room on the sides. As far as performance gains, well clean air is good, I don't believe in trusting a window screen.
jvthundercat is offline
Old 01-16-2014 | 04:39 PM
I actually contacted K&N and discovered that the 9" wouldn't flow enough air for my motor. Check the airflow on your flame arrestor, you may be surprised as to how little they flow also. I used the 14" with a velocity stack style housing to smooth the flow into the carb. Fortunately for me, Velocity has a cold air intake built into the rear deck, I just had to open it up a little and it actually fit inside better with the velocity stack style housing.
ThisIsLivin is offline
Old 01-16-2014 | 04:59 PM
Good advice ThisisLivin. This is what I did on my last build with a pair of 472's.
