Class action lawsuit ( mercruiser) vapor-lock issues. >
Old 06-19-2014 | 11:23 AM
  #81
F-2 Speedy's Avatar
heres Merc's item 4&5, kinda price'y, but Im sure an auto parts place could find you something, you need to drill and tap the fuel rail
https://www.mercruiserparts.com/Show...+And+Injectors
F-2 Speedy is offline
Old 06-19-2014 | 11:29 AM
  #82
Thank you for your quick response.
My another question. Is it already installed by the Mercriuser or I need to do it?
If I have to do it can I run line with the check valve out of the engine compartment to avoid bleeding it there?
Capt.Yar is offline
Old 06-19-2014 | 11:38 AM
  #83
Originally Posted by US1 Fountain
'99 502's. Never had a problem till 4 yrs ago. Last yr it happened every time I went to start the motors (both of them too!) after sitting a a bit, even thought the temps were only in the 80's. Boat is not leaving garage till I do the return lines to tank. Looking at my tank, I have no way to tap into it, so gotta run long 2 hoses up to the fill hose and tee into it there.
A buddy had the check valves installed on his 350's, didn't appear to do any good.
Just buy a bulkhead fitting, then you'll have an easy way to plumb a return line.
Jonesyfxr is offline
