ID CAT 3208t no numbers >
Old 01-25-2014 | 06:50 PM
ricardo mann's Avatar
Default ID CAT 3208t no numbers
[ATTACH=CONFIG]517151[/ATTACH][ATTACH=CONFIG]517152[/ATTACH]HI started work on cigarette today ? i think i am going to require sum help with this one ? can not fined any data tags or engine numbers on the engines . this means i can not order parts from cat dealers in UK it seems like the engines might have had rebuilds at sum time and cleaned and painted yellow . any thoughts on this ? I am going to post photo of engines and transmission setup and see if anybody might be able to id this build and set up cat 3208t Thanks Ricky
Attached Thumbnails ID CAT 3208t no numbers-img_3159.jpg   ID CAT 3208t no numbers-img_3181.jpg
ricardo mann is offline
Old 02-08-2014 | 10:49 AM
Try Boat diesel forumn. They are great for diesel tech and info. Full 3208 info there.
Dave
Allicat38 is offline
Old 02-08-2014 | 01:25 PM
on the 3208 cat engines everything is usually on a foil tag on the valve cover..if you dont see them n the vc also look on the side of the block,if not then you may be out of luck.. http://www.bing.com/images/search?q=...electedIndex=6
FIXX is offline
