-   -   Hinge pin threads stripped (https://www.offshoreonly.com/forums/general-q/308225-hinge-pin-threads-stripped.html)
flyinlow 02-05-2014 05:41 PM
I just rounded up the tools and inserts for 5/8 x 18 if you would like to borrow the tools, no charge for the inserts.
They are a one piece insert that stakes in place and won't pull out like helicoils which are basically just a stainless steel spring with a thread profile.
Sunrocket24 02-05-2014 06:56 PM
Originally Posted by Black Baja (Post 4069771)
I've installed the hp pins a few times and never even took anything apart...
So the trim senders will fit on top of the HP pins? If so I want to do the conversion on my new transom assembly.
vbot24 02-05-2014 07:48 PM
No you can't run the senders with hp pins
Also the gimble ring on an hp transom assembly is stronger, so just adding the hp pins doesn't make it an hp transom.
whoya 02-05-2014 07:54 PM
I did a Helicoil and has been holding up just fine.
flyinlow 02-05-2014 08:15 PM
A helicoil most likely will last as long as the boat, I typically work on much larger machines subject to considerably more severe operating conditions and have seen helicoils fail too many times so have gotten completely away from them and gone with the staked in one piece inserts. They are more expensive but have never seen one fail yet. Compared to the labor and down time the price of the inserts is insignificant.
Cole2534 02-05-2014 09:18 PM
Originally Posted by zz28zz (Post 4069723)
I checked McMaster Carr. They have no kits that include 5/8-18. Same with O-Riellys.
Grainger has a 5/8 -18 kit, but costs almost $300!
Checked around locally at bolt and industrial tool shops. Prices range from $100 to ~$150.
Found a couple of kits on Ebay for ~ $50 that don't include the oddball 41/64's drill bit. That looks like the way to go.
Weird.
http://www.mcmaster.com/#standard-th...nserts/=qkiau1
zz28zz 02-06-2014 04:16 PM
I had pictured in my mind initially that they screwed into the bell housing, but I now understand they attach to the gimble ring. Got any pics of the HP pins installed. I search around but couldn't find any.
zz28zz 02-06-2014 04:47 PM
I did find this: Ref post# 11
http://www.offshoreonly.com/forums/d...housing-2.html
Not sure if they are talking abt the same kind of HP pins or not.
The helicoil is looking better and better.
jvthundercat 02-06-2014 05:28 PM
Originally Posted by Cole2534 (Post 4069907)
Looks like $3.45 to me for a .938 length
flyinlow 02-06-2014 06:34 PM
That price is for one insert but no tools
http://www.autotoolworld.com/Helicoi..._p_142364.html
this is the kit you need, it doesn't include the 41/64 drill bit which may be hard to find but you can use a 5/8 bit with aluminum, it is only 1/64 smaller and the tap will easily cut that difference and guaranty full thread engagement. Like the others have said make sure to use red loctite 271 on the insert . Make sure that the loctite sets up (it's anaerobic so only fully sets up where there is no oxygen) before applying anti seize to the threads on the pin.
