Odd knocking sound on 500EFI XR setup >
Old 02-11-2014 | 08:02 AM
my capitains call has a nasty sound at times from the back splash flapper...sometimes if it shifted in the right spot it sounds nasty...
prostock3 is offline
Old 02-11-2014 | 09:42 AM
VoodooRob's Avatar
Did you buy it?
VoodooRob is offline
Old 02-11-2014 | 12:46 PM
No, not yet but it is my 1st choice. I talked to the guy in Cleveland about his with the 525s, it has no AC so that's not gonna fly for me or the gf.
s022mag is offline
Old 02-11-2014 | 02:32 PM
VoodooRob's Avatar
PM Sent
Old 02-11-2014 | 07:40 PM
Remember AC only works with gen and shorepower. You can add it yourself for around $2K and a little work.
Wilks is offline
Old 02-13-2014 | 06:45 AM
Gen or shorepower....
Old 02-13-2014 | 07:37 AM
mrquad1's Avatar
dometic makes a 12 volt ac system,will require a 3 bank batt pack tho.
mrquad1 is offline
Old 02-14-2014 | 12:56 AM
Next time you look at it i would Pull the drain screwws on the drives. 2 on each ( if you haven't) That can tell a story about your purchase. XR's schread metal and sometimes you can just pull a screw and be sure. Bring an extra screw and throw it in while you inspect the one you pulled. and bring some white paper towels. you probly know this but i didn't at one time . Hope this helps
mcprodesign is offline
