Selecting a manifold for AFR 265's - single versus dual plane - thoughts anyone?
#71
#73
Waste of time.
You are overthinking.....Unless, you know how to properly shape the plenum and esoecially runner entrances, compute port lengths and properly adjust them, and + figure your min csa and port taper needed...but, with such a 'basic' performance build (ie: rpm/cam/etc) then that wouldn't be worth the 1k+ for someone to do it for you.
You have a good build going. Bolt on that damn intake, get your pushrods in, and go boating.
#75
I did some extensive port matching and also some bowl work as well on my heads and air gap intake..... I got some aluminum cutting fluid and it works really good but don't go too fast with the cutter or it will melt the aluminum and clog your bit..... I matched It all up on the fel-pro gasket and it all matched up perfectly....... Here is a previous thread that shows the amount of material I had to remove.......
http://www.offshoreonly.com/forums/g...ead-509-a.html
#76
Yes, i'll clarify.
Waste of time.
Waste of time.
#78
Go have a few buds and get the damn thing done already.
#79
#80
In fact, on intakes that do, you need to tap and plug that holse so it won't be open to the runner.
Anyway, as far as dual planes go, 70% of the power to be gained by these are in the plenum - mostly transition from plenum to runners. Yeh, hard to get to on lower plane. And in the more pronounced curves on the runners. Sometime you have to whole saw these areas open to access this. Kinda overkill for most I/O builds, but atleast most 496+cid engines better utilize a smaller (Vic Jr/ Dart 4150, or etc) single pane intake anyway. Many 540+'s can utilize a 'medium' size single plane like a Victor 454R or etc.
