How do you adjust the tension on a Zero Effort Throttle Control
My port engine throttle lever on my 1992 Merc 200 hp keeps slipping back . I have to keep bumping the throttle up. Where is the tension adjustment. These throttles are new to me.
Thanks Wannabe |
On my Eddie marine elites there was an Allen head screw in the rubber where the stick goes down
There has to a screw somewhere. I hope someone with experience on the zero efforts can chime in. The eddie marines are different.
Wannabe |
Sounds like one of the detent balls fell out. They sit on little springs and hold the throttle in each position. Did you have these apart?
http://www.offshoreonly.com/forums/archive/t-83912.html
Old thread but no adjustment on mercs. Just a ball and spring. You can replace spring apparently. |
If you take the thing apart.there is a pocket with a little spring and ball on the side plate. the spring pushes the ball into a curved piece of plastic on the lever. That controls the tension but its not really adjustable per say, but with a little thought you can modify it to do what you want..
Thanks guys
I just takes a little fiddling with it. I didn't like the ratchet feel, a little work and it was nice and smooth.
| All times are GMT -5. The time now is 08:48 AM. |
