View Poll Results: Machine Shop or Drill / EZOut
Machine Shop
2
66.67%
Drill and EZOut
1
33.33%
Voters: 3. You may not vote on this poll
Broken stud in EMI Thunder manifold / header??
GO rent a wire feed welder for like 20 bucks at a rental shop.!
Get a huge Nut (1/2 in or so) and put it on the manifold riser. Center it on the borken stud..
Then take a wire feed welder and fill the nut , Welding the stud to the nut. First get a little weld to stick to the stud then let her rip til the nut is full of weld.
Then Unscrew it. This will also make heat and that will make it unscrew real good omnce it cools.
Agree with this method, with one exception. Use a fender washer, weld it to the remaining stud 1st, you will get better penetration to the stud. Then weld a nut to the washer. Let it cool a bit and slowly work it out. As stated in the above posts this is one of the best and easiest methods. If you drill, use a small bit at 1st, make sure it is centered perfectly, lube the heck out of it, then slowly go bigger. After you get a good hole you can use a small carbide on a Dremel or die grinder and work the remaining stud to just about where the threads show and pick the remaining pieces out. Not the quickest method but does work as a last resort. We use to use both methods at the Cat dealer I use to manager years ago.
Pete
Sometimes if not much thread to the stud is exposed, a castle nut just a c hair bigger than the stud placed upside down over the stud will give you more surface area to weld.
Take it to a shop that has a MDM -metal disintegration machine. http://www.youtube.com/watch?v=YbeKxFBZrF8
