Cleaning K&N air Filter >
Old 08-14-2002 | 10:04 AM
BAJA WILL's Avatar
Registered User
Default Cleaning K&N air Filter
What is the best way to clean this filter? Should I use water or some type of chemical?
WILL
BAJA WILL is offline
Old 08-14-2002 | 11:14 AM
GMScott
Will:
K&N has a kit to clean & "charge" the filter. I have one on my diesel truck. I think there is a period of time you need to let it soak prior to using it again. It's been a while since I cleaned mine. Thanks for the reminder.
Jerry
Old 08-14-2002 | 11:30 AM
stevejohns
You can use a real mild soap. But you will need the new K+N oil and it usually comes with the cleaner.
Old 08-14-2002 | 08:41 PM
Von Bongo's Avatar
Back in the motocross days we cleaned them with 409, washed them out with warm water, let them dry and the sprayed them with the pink k&N filter oil. Did the same thing with my boat K&N. No problems. Do not use air to dry it unless it's like a hair dryer.
Von Bongo is offline
StillHaulin@63
09-21-2006 10:07 PM
Dave1972
05-28-2006 12:20 AM
Dave1972
10-08-2005 10:12 PM
JeffGrice
11-06-2004 10:40 PM
Mr. Gov'nt
Nordic
3
10-04-2003 09:33 PM
