Installing WB 02 in IMCO power flow elbow >
Old 03-13-2014 | 08:13 AM
Maybe this is for you?
http://howellefi.com/adaptor-o2-sens...arine-use.html
Jeff
hallj is offline
Old 03-13-2014 | 08:57 AM
Originally Posted by Budman II
Do you need to use a stainless steel bung and a special type of weld? I'm not a welder, so I have no idea. I was considering putting a set of bungs in the divorced collectors for my Lightning headers - they have a stainless steel inner pipe and a mild steel outer. Is there something special that has to be done with these, or just a regular old MIG or TIG weld?
I use a SS bung, but I am welding to SS. We tig weld them, which is really the only way to go. I'm not sure what to do in the case of your exhaust with the 2 different materials. I would consult a welder.
Eddie
Young Performance is offline
Old 03-13-2014 | 09:26 AM
Originally Posted by hallj
Wow! $95.00 for a brass fitting - doesn't even include the sensor! I guess that's because it has the word "marine" on it. Doesn't sound like it would work on most stainless risers, because it requires a flat spot for sealing. Oh well, thanks for the link.
Budman II is offline
Old 03-15-2014 | 10:48 PM
Where's a good place to pick-up some stainless bungs?
If you have Capts choice, should you keep it set for thru-hull mode when the O2 sensor is installed?
Thought I saw that somewhere.
zz28zz is offline
Old 03-15-2014 | 11:18 PM
http://www.frozenboost.com/product_i...9e3360e099714f
I ran mine with silent choice all the time. ran a point or so richer on the O2 but never had a problem.
Griswald is offline
Old 03-16-2014 | 08:57 AM
depends a lot on the header/exhaust, I have lightning w/silent choice, have killed 3 in no time, never went to thru prop, even tried a 02 extender w/packing, but the lightnings dump the water way to close to where the 02 is...no win for us...good luck
ezstriper is offline
Old 03-16-2014 | 03:00 PM
Thx for the link Griswald. I like the lip idea on the bung.
ezstriper, how far was the sensor from the point where the water mixes w/exhaust? Where you running a long duration cam? Did they die at idle or at higher RPMs?
I've heard of people using O2 sensors screwed into spark plug de-foulers on cars. They were used to stabilize the readings on the post cat sensors to prevent getting cat inefficiency errors. Might help with a wet exh. Just at thought..
zz28zz is offline
