525SC upgrades Marine Kinetics Cam >
Old 03-12-2014 | 07:11 PM
Rookie's Avatar
Originally Posted by I.C.U.Lookin
Rookie dont think they were factory 525sc. Similar build with 250 blowers. He just switched cam to HYd roller.
Ok, I could see him pulley'ing up and creating a furnace and losing power that way with if it was a 177.
Rookie is offline
Originally Posted by oneanddone
Don,
I set Timing at 26
Demon carbs 825 with 80/90 on the jets
Plugs looked fine after running a few WOT runs.
To be honest I never really ran them hard before I did the upgrades the initial numbers could be off a bit but with my calculation after upgrades I'm coming up with 22%.. I guess I am really looking at my new numbers.
Did you upgrade to the 250 blowers? 525's had 177 blowers.
Also please bump your timing to 32* before you send your exhaust valves out the back of the boat!
Sounds like your doing something different now than you did before possibly over trimming
Merc 525 factory timing was 35*
Unlimited jd is offline
Old 03-12-2014 | 07:12 PM
Seems to pull RPM without hesitation to WOT its the speed that seems to plateau after 4800
Is it possible that you are only getting to 5600 rpm by over trimming the drives? That would explain the high slip and lack of speed gain.
Eddie
Young Performance is offline
Old 03-12-2014 | 07:14 PM
Looks like a few of us posted at once
Old 03-12-2014 | 07:18 PM
Eddie
Good point Eddie. I have trimmed the boat the same on all runs as far as Fountain indicators never past the number 4 mark with the TRS drives it seems to loose speed beyond that
oneanddone is offline
Old 03-12-2014 | 07:24 PM
If pulls right to 5600 yea sounds like a major prop slip issue. Call Fountain and get there input on the TRS with that hull they may have some thoughts.
Agree with Red, if your total timing is 26 degrees then you should consider bringing it up to at least 30. There should be an increase in power for this as well. At 6 lbs of boost should be fine with 91 octane. Make sure you are setting timing to total, not initial.
Youngs question is a good one, were you overtrimmed and slipping the prop?
Don Johnson is offline
Old 03-12-2014 | 07:31 PM
the op said base timing at 26 nothing mentioned about total timing.
mike tkach is offline
Old 03-12-2014 | 07:33 PM
That's total at 26 mike. It was a typo. Lol
Crude Intentions is offline
Old 03-12-2014 | 07:34 PM
Bringing the timing up is a good idea but started there. defiantly not over trimmed
Old 03-12-2014 | 07:38 PM
my mistake.if he has total timing at 26 and running the jets he has in it i would be afraid to go wot,imo its way to lean and the exhaust valves are glowing red hot.
