please help ! >
please help !
please help !
Old 03-30-2014 | 10:39 PM
on a 330, a bravo is fine, less weight, less complexity, less drag...you will need to fill and recut the hole though.
phragle is offline
Old 03-31-2014 | 08:24 AM
I'll echo what others have said about the wet exhaust joint on Merc manifolds being the downfall of many an engine. I think an excellent upgrade for these engines would be a set of the 496 Merc manifolds, maybe a used take-off set. These are almost a bolt on item on a 330, and they eliminate the wet joint that causes all the problems.
Budman II is offline
